I have about one hour to work on the tractor before my wife finds something else for me to do. I usually check the archives before I post a question, but sometimes I can spend an hour there, and so this time I post first and then go searching. I tore out the old wiring when I began the engine rebuild last March. I am putting the wiring back together now, all new wire, correct gage, etc., but I have run into a snag. I found a 12V wiring diagram with the help of the archives, but I'm not clear about a couple of things. One is, how I am supposed to wire the solenoid? There are four terminals; one large terminal on either side of the solenoid and two smaller ones, marked "I" and "S" in between the larger two. From the diagram I have, it appears that the "+" side of the battery goes to some terminal on the solenoid, obviously one of the two large terminals. I am left to assume, because the diagram is unclear, that the other large terminal of the solenoid connects to the starter terminal. I do not know which large terminal connects to what. The diagram shows a wire from the solenoid to the push-button starter switch, with the other side of the starter switch connected to ground. I expect that either the "I" or "S" terminal connects to the starter swtich, but which one? The last connection is between the solenoid and the "+" terminal of the ammeter. Again, I expect this connection begins at either the "I" or "S" terminal. Can someone please explain which wire goes where? My other question involves the terminal block. There are three posts on the block, one on either side of the resistor and then a "third". Since my ohmmeter reads open between this third post and either of the other two, I take it to mean that I can run a jumper between one of resistor posts and the third post and then consider the third post to be electrically the same as the post it is connected to. I seem to recall that that is how this thing was when I took it apart. Is this correct, or should that third post be somehow connected to a specific point on the resistor? The third post is open with respect to either other post (when there are no wires attached to any post); is this OK or does it indicate that I should have forked over the $15 for a new terminal block when I was at the tractor store getting a new ammeter this week? Two final notes: This is a 2N front mount, and, the way I have it wired now, the side marker lamp does not light when I turn on the ignition switch. Any help will of course be appreciated. I'll go look in the archives for now.
