Order Ford 8N Parts Online
8N Lift Stuck 1/2 Way Up
RICK/GA
11-25-2002 05:53:00
Just worked my 8N for several hours this weekend with my 5 foot box blade. Made a reverse move to fill a large hole and backed up and the lift just stopped working. It is 1/2 way up and with the control lever down the arms will not go down. The hydraulic fluid was low, but subsequent filling made no difference. This lift has worked without fail for the last 8 years. Plan to take it apart this week just had hoped someone has a good idea why this may have happened.
Gene -WIS.
11-25-2002 18:18:01
 Re: 8N Lift Stuck 1/2 Way Up in reply to RICK/GA, 11-25-2002 05:53:00
If it has been working all these years, my guess would be that because the oil was low, it probably got hot and the valve spool in the pump got stuck. The pump only raises the arms up, when you let them down, you are just opening a valve spool to let the oil drain out of the lift cylinder.My 8N did the same thing, but mine had been sitting for 28 years and the lift cyl. had water sitting in it and the piston came up half way and froze in the rust!Remember, you need to pull the PTO shaft to drop the pump.
