Order Ford 9N Parts Online
Has anyone tried a snowblower on a 9N?
Reb
11-25-2002 14:59:23
I am looking at buying a 9N that has a front end loader already on it but I would rather have a blower. I found a 60" Westco blower in pretty good shape that requires 15 to 30 hp. Has anyone tried a blower on a 9N? I would like to get a feel for this combination before purchasing it.
Thanks
ThompsoN
11-25-2002 16:05:54
 Re: Has anyone tried a snowblower on a 9N? in reply to Reb, 11-25-2002 14:59:23
I know several guys who use a blower, although they are using 8N's so there are a few differences. The typical pull-behind V blowers work fine as long as you're not trying to blow too much at once and it's not too hard. Stay ahead of the drifts and you'll like it.
third party image
Scott.ID
11-25-2002 15:58:51
Reb,
I have used a blower many times on my 9N, and it worked just fine as long as the snow wasn't too heavy.
If I was to do it again, I would try to find a rear mount "V" type blower that operates while the tractor is moving foreward. A HECK of a lot easier on the neck!
Several members of this board have the mower I'm talking about, maybe one of them will post a pic.
my nickels worth,
Scott
MikeC
11-25-2002 15:47:44
I have seen a couple of posts in the past from guys that have the 3pt mounted snowblower. The biggest issue seems to be that they plug up if the snow is wet.
I used to have a L&G tractor with a snowblower on the front. I did not care for it especially when the wind was blowing the wrong direction. I would get covered with snow.
simonmeridew
11-25-2002 17:07:44
 Re: Re: Has anyone tried a snowblower on a 9N? in reply to MikeC, 11-25-2002 15:47:44
If the snow is dry it works great; if it's heavy or wet, the problem is that when you stop, the blower stops, meanwhile giving the heavy snow a chance to become "frozen" inside the blower, and it may not want to start again. In short, another issue with the "live PTO" deal. With a live PTO if you stop the blower keeps going which won't allow it time to "freeze up".
your mileage may vary
simonmeridew
Works better on your driveway! - LOL
11-25-2002 15:36:50
