FRONT CRANK BOLT
PHILGA.
11-25-2002 16:15:53
Could someone please tell me what size socket is needed to remove the front crank bolt? THANK YOU
Dell (WA)
11-25-2002 22:58:30
 Re: FRONT CRANK BOLT in reply to PHILGA., 11-25-2002 16:15:53
Phill..... .the crown headed frontcrank bolt uses a 1-5/16 deep 6-point socket and a long extension thru the radiator crank hole. Torque is 150 ft/lbs.
Big secret trick to eazily remove crankbolt..... .stuff a soft 1/4" clothesline rope innna sparkie hole and then wheather your loosening or tightening, your crank will rotate and push the piston upppa 'ganst the rope and you'll have plenty of purchase to torque against..... ...Dell
Disclaimer......
11-26-2002 06:58:17
 Re: Re: FRONT CRANK BOLT in reply to Dell (WA), 11-25-2002 22:58:30
Be sure to leave one end of the rope sticking out of the spark plug hole..... ..... ...
