Don't forget to flush!!!
Ron/PA
11-26-2002 11:28:00
With cold weather coming on, just a reminder to drain and flush the hydraulic, tranny system on the N's, 2 years ago, I went to move my super A and it wouldn't move, I finally found a block of Ice in the tranny, so now I keep a close eye on all our tractors. I spent all day sunday changing the fluids in 5 tractors and all of them showed signs of water. $30.00 for 5 gallons of oil is wayyy cheaper than a new rear.
Calling for 6 inches of snow tonight, so I'm hoping for it to hold off until I get home from My runs. Happy thanksgiving Ron
Farmered
11-26-2002 19:50:55
 Re: Don't forget to flush!!! in reply to Ron/PA, 11-26-2002 11:28:00
Hey, Find someone who has a waste oil furnace. They will be glad to take your oil, they may even furnish barrels to put it in. Like someone else said, NO antifreeze also no gasoline. Solvent is ok in most furnaces and so is diesel. Good luck, Ed
8ndexta-ger
11-26-2002 12:01:06
What do you do with the gallons and gallons of oil you drained out? I've found service stations aren't real happy to take my old oil.
Ger
Stephen Horton
11-26-2002 16:11:15
 Re: Re: Don't forget to flush!!! in reply to 8ndexta-ger, 11-26-2002 12:01:06
Our local Walmart in Texas has a 'public tank' available near the auto service garage for this purpose. It has a very large capacity, so they don't mind the volume.
stephen
Jim.UT
11-26-2002 12:29:39
My NH dealer will take it from me. Also some auto parts or service garages will take it. Sometimes local laws will require them to take it if you bring it in, but they may be able to limit the quantity you bring in at one time.
don t. - 9n180179
11-26-2002 12:28:29
Jiffy Lube takes used oil, motor or hyd.
They won't take antifreeze.
