Hey N-gineers!
Ron from IL
11-26-2002 11:56:45
Does anybody know the APPROXIMATE horsepower needed to turn a power steering pump? I know, I know--what car, etc., etc. I got a free pump from a friend off (I believe) a Nissan (PLEASE, no Nippondenso jokes!), and I'd like to use it to power a small hydraulic cylinder for a garden'sized dump trailer. Would 3-H.P. be enough?
TIA
Ron
kevin
11-26-2002 16:43:08
 Re: Hey N-gineers! in reply to Ron from IL, 11-26-2002 11:56:45
Awright, lets look at it this way: 1 hp = 33000 ft-lb/min.
so maybe you want to lift 330 lb 3 ft. in 6 sec
330 lb x 3 ft = prox. 1000 ft-lb divided by .1 min
giving 10000 ft-lb/min which requires about 1/3 hp.
Now, let's say the overall system efficiency = 50%
so .33/.5 = .66 hp. minimum in this example.
Just scale these guesses up to meet YOUR requirements. Good luck and don't pinch yer fingers. I'm an electronics engineer NOT mechanical.
YMMV
kevin
Jet9N
11-26-2002 15:49:32
I'm sure any small engine would serve your purpose
fine. I have a 10 HP lawn tractor that I built
some years ago. Later I built a loader on it and
run the loader with a power steering pump. Then
told the wife it didn't look balanced and built
a back hoe for it. This pretty well loads the 10
HP engine. Blew one pump out, just a little too
much for it.
I believe it's set for about 900 PSI.
HTH
Jet
Dave Smith
11-27-2002 04:34:23
 Re: Re: Hey N-gineers! in reply to Jet9N, 11-26-2002 15:49:32
How about posting a photo of it.
Dave <*)))><
Jet9N
11-28-2002 11:36:46
 Re: Re: Re: Hey N-gineers! in reply to Dave Smith, 11-27-2002 04:34:23
Don't have the capabilities. Sorry.
Jet
Jim Spencer S.E. Michigan
11-26-2002 13:48:16
Ron:
There are a lot of considerations that must be made and just common sense will give you a better understanding.
For instance the area of a circle is 3.1416 times the (radius X radius). This means that if you had a 10inch diameter cylinder it will have 78 square inches in area. (5 X 5 X 3.1416). Ten (10) PSI would allow you to raise 780 lbs. You could do this with a 1/16 h.p. air compressor running off your battery but it would be slow.
I am not trying to be smart but get you to think. If you use a 3" dia. cylinder(1.5 X 1.5 X 3.1416)a little over 7 square inch area it will take 100 PSI to exert a 700 lb force.
I don't know what pressure a power steering pump will produce. It would be nice to know this unless you just want to experiment. I would think that probably 1 H.P would be enough for what you want to do. I do think that on an automobile it takes more than 1 H.P. during times when the car is stationary and turning the wheels, but during driving on the hyway it would use very little H.P.
I am a retired engineer, but I have been in Manufacturing all my life.
When Henry Ford made his first car I am sure many modifications were made before he developed the "TOWN CAR". The most important thing is to have fun and building the dump trailer sounds good to me.
Jim
kevin
11-26-2002 12:21:05
Depends on how fast you want to do the work. The pump for my loader is 7 gpm at 2500 psi max (Vickers V20 vane pump) and this will take over 20 hp by way of comparison. I have done some calculations in the past, and determined that about 6 hp was the min pump hp I could tolerate before I got a deal on this one. Do not underestimate how much power it takes. Having said that, for something like a garden trailer lifting a couple hundred lb. not too fast, you are probably in the right ballpark with your 3 hp. If you want more specific numbers, we will need the pump efficiency, displacement, pressure, load and lifting speed.
fwiw
-kevin
Willy-N
11-26-2002 12:16:55
I have a 5 1/2 hp engine that drive the pump for my 20 ton 4" cylinder Log Spliter it seems 3 hp would work your pump to do what you wanto do. Mark H.
