Really Dumb Question
Get @#$#^ PTO Clutch Off - How?
RICK/GA
11-26-2002 17:00:06
This one is a little embarrassing. How do you get the PTO clutch End Off the End of the PTO Shaft. This One is not in my IT manual.
Rochester (WA)
11-26-2002 18:46:34
 Re: Really Dumb Question - Get @#$#^ PTO Clutch Off - How? in reply to RICK/GA, 11-26-2002 17:00:06
FYI for anyone who has one of these lying around--The rod that goes from the starter button to the starter switch on a 9/2N works as an excellent drift to drive out the roll pin on an ORC. It's the correct length and width to do the job right. Casey
BOB
11-26-2002 17:11:44
RICK do you mean overrunning coupler on pto shaft?if so there is a screw plug 2 of these,take them out and line them up with the roll pin in center part of coupler,tap out with a punch. BOB
ZANE
11-26-2002 17:07:26
Remove the grease fitting and the 1/8" pipe plug opposite the grease fitting and turn the ORC until the roll pin is in view. Use a flat ended punch of the correct size to drive out the roll pin and then you can pull the ORC off.
RICK GA
11-26-2002 18:12:04
 Re: Re: Really Dumb Question - Get @#$#^ PTO Clutch Off - How? in reply to ZANE, 11-26-2002 17:07:26
Thanks guys! I am pretty sure that I had done this once before but have forgotten. I had the two grease fittings off but there was too much grease in the hole to see the roll pin. I'll feel good about doing it tomorrow.
