Ford 2N
Richard
10-07-1998 08:37:57
What is the diffrence between an 8n, 9n, and a 2N ?
Richard WY
05-30-2000 19:22:27
 Re: Re: Re: 8N..no power in reply to dave#1, 05-30-2000 03:36:49
absolutely if it is not painted with Sears Weatherbeater then it will not run right.
John Ragan
10-07-1998 09:28:08
 Re: Ford 2N in reply to Richard, 10-07-1998 08:37:57
The year the were made. I think it goes 9n,1938:
2n,1942: 8n, 1948: Each model change braught some advances tranny and hydro. Plus I believe more horse power?? Transmission startred out three speed with the 9n and ended up four speed with 8n.
The 8n also has draft control for plowing. Just keep check back. These guys know alot abou these great little tractors. They will let you know more.
jake from il
10-07-1998 10:40:32
 Re: Re: Ford 2N in reply to John Ragan, 10-07-1998 09:28:08
9n is same as 2n exept during war the n came without rubber tires and gen.
STUMP PULLER
05-30-2000 19:15:08
 Re: Re: Re: 9N Won't Fire-up in reply to Jim(TX), 05-30-2000 18:53:45
YOU WILL GET 12V OPEN POINTS AND ESSENTIALLY ZERO VOLTS WITH THE POINTS CLOSED. GOOD LUCK
