Order Ford 8N Parts Online
Did 52 8N's Have a Lower Reverse Gear?
Arthur Brestlin
12-03-2002 03:13:10
I was browsing on a New Holland Compact forum yesterday when I read a post claiming that late 52's had a slower reverse. I had not heard that before. Can anyone verify that as being so?
jack nc
12-04-2002 15:57:25
 Re: Did 52 8N's Have a Lower Reverse Gear? in reply to Arthur Brestlin, 12-03-2002 03:13:10
as i understand it ,late in 8n production they started using naa transmissions in 8n's. not all 52 have the slower reverse. however they all have a bump at lower left and rear of transmission housing, but the late 52's had a larger bump that comes almost out as far as the bolting flange.
Mike OH
12-03-2002 07:59:17
My 52 8N, S/N 515797, has the bumpout as Soundguy describes, but I can tell you that reverse in it is faster than on my 53 Jubilee. Makes it kind of scary backing into the barn with the brush hog on it. (knew I should have made the door wider)
Soundguy
12-03-2002 11:10:15
 Re: Re: Did 52 8N's Have a Lower Reverse Gear? in reply to Mike OH, 12-03-2002 07:59:17
Don't get me wrong... my reverse is potent too..makes you wonder.
Soundguy
Soundguy
12-03-2002 04:58:11
Yes some did.. though I'm not sure what serail number started the changeover.
My 52 8n, sn 504580 has the lower gear.
To identify the lower gearing, look on the lower left side of the body/tranny casting, around where your left foot would sit on the running board, and there should be a bulge in the casting to make room for the gear.
Soundguy
J.J.
12-03-2002 16:07:44
 Re: Re: Did 52 8N's Have a Lower Reverse Gear? in reply to Soundguy, 12-03-2002 04:58:11
Very very interesting. Thanks so much for sharing that bit of information with us. I am looking for a 52 and will sure look for that abnormality.
Thanks again.
