Hello again Allen..... ....this is the new, kinder, gentler, user friendly Dell. To answer your question, I quote from my well worn I&T FO-4 manual: For 9N brake service: Jack-up rear end of tractor and remove the rear wheels (caution: tire could be heavy) remove fender support brace. Remove the stud nuts attaching the axle bearing retainer to the axle housing (save the shims) Pull the axle shaft and brake as an assembly out of the axle housing. (no, the 5 gals of hydro/tranny oil should NOT leak out the axle trumpet mouth) Turn the brake adjuster eccentric counterclockwize to back the brake shoes away from brake drum. Lift the brake backing plate off the bearing retainer studs. Remover brake shoe retracting springs. Remove brake shoes. The brake lining is riveted to the brake shoe, and new lining is availabe for installation on a used brake shoe. New 17" brake shoes and lining are also available as an assembled unit. Reinstall brakeshoes in reverse order of removal. Be sure that the upper brake shoe fits squarely in slot of adjuster link. Note that upper brake shoe return spring is color coded green and lower spring is color coded red. Finish the job by adjusting the brakes. Oh by the way, you might want to consider re-newing your axle seals, as described in the I&T FO-4 manual. And consider using a product called "Sure-Seal" for your axle shaft..... .....respectfully, Dell
