Order Ford 8N Parts Online
8n sector seals (4 req. )
Arnold
12-03-2002 15:04:03
I seem to only have room for 1 seal on each sector arm on a 52 8n.Am I puting them in right? I put the seal on the outside of the sector shaft and inside the bushing mounting hole.. there is room for only one??
Ron (8n509270)
12-03-2002 15:14:33
 Re: 8n sector seals (4 req. ) in reply to Arnold, 12-03-2002 15:04:03
Arnold,
If you are looking at the Ford parts manual it is deceiving. The old seals were 2 part, a seal and a metal retainer. The new Ford part (#D5UZ3591A) is a combination seal and retainer and only 1 is needed per side.
I just went through this rebuild if you need any help let me know.
Ron
Arnold
12-03-2002 16:04:39
 Re: Re: 8n sector seals (4 req. ) in reply to Ron (8n509270), 12-03-2002 15:14:33
I went to a New Holland dealer and told them I needed bearings and seals for the rebuild and they said it takes 4 same part #d5uz3591a, that is what they sold me. 2 of the seals were in a CNH bag and 2 in a new holland bag both all 4 bags have the same part number. Did you use 90 wt. oil or grease in your gear box?
ARNOLD
12-03-2002 19:31:09
 Re: Re: Re: Re: 8n sector seals (4 req. ) in reply to Ron (8n509270), 12-03-2002 19:13:58
Thanks for the info.Ron I fill comfortable now about using the single seal. thanks again
