HYD Pump Pressure ?
RayPHX
12-03-2002 15:17:02
Checked the archives without finding and answer.
What should Out-put Hydraulic Pressure be for a 52 8N pump ??
Can't find the answer anywhere. (or I'm just a little thick headed)
Arnold
12-03-2002 16:17:55
 Re: HYD Pump Pressure ? in reply to RayPHX, 12-03-2002 15:17:02
My FO-4 manual Said a Minimum of 1600 psi with the lift arms fully lowered and weighted to prevent lifting the relief valve should open.
114 page 36 in manual.
Ed Gooding (VA)
12-03-2002 15:22:13
Hi Ray. Approx. 1500 psi, with the relief valve set to pop open at 1600 psi.
Hope this helps..... ..... .Ed
'52 8N475798
