Radius rod
roger
12-07-2002 09:35:18
got the 8n totally apart. going to rebuild engine and replace everything from breaks to bearings. all ready have all sheet metal parts sanded and primed.but,want to replace drag link ends.problem is that there is just one clamp up front and the rear looks to be one piece,no threads just bolts through the arm on the steering.any way to replace this end or do i have to get a new drag link? thanks in advance. roger
Darrel(ok)
12-08-2002 11:21:21
 Re: radius rod in reply to roger , 12-07-2002 09:35:18
I fixed mine a little different. I went to Ford/New Holland and bought two rear tierod ends for a Ford 2000 diesel tractor that are right hand threaded. I also went to Napa and bought a tierod adjusting sleeve for a 73 Buick Electra. It has the same size threads as the Ford tierods.
I put the sleeve on one of the tierod ends and screwed it on untill the tierod end was about halfway through the sleeve. I put the tierod on the steering arm with the nut on hand tight.
Then I held the draglink along side the sleeve and marked it at the halfway mark at the sleeve. Then I cut the draglink end off and ground a bevel on the cutoff end of the draglink. Then I put the draglink in a hydraulic press and pressed the lefthand threaded end of the sleeve onto the draglink about halfway. Then I mig welded the draglink down the seam of the sleeve.
I put the tierod back on the sleeve about half way and put a clamp on the sleeve. I put the tierod draglink assembly back on the tractor and positioned the seam down so it doesn't show and tightened the clamp. Then I adjusted the front sleeve to get the wheels lined up. I haven't had any problems from it.
Darrel.
roger
12-08-2002 13:27:31
 Re: Re: radius rod in reply to Darrel(ok), 12-08-2002 11:21:21
thanks to all for the response.the ball joints seem to be in good shape,so i will just go with new dust covers for now.thanks again,and i will more than likely be back with more questions and problems. roger
ZANE
12-08-2002 08:58:12
I have fixed many by buying the short later model ends and cutting off the old one and welding on the new short ones. Works good. Just try to be sure you end up with the right over all length again.
Zane
denton
12-08-2002 13:04:24
 Re: Re: radius rod in reply to ZANE, 12-08-2002 08:58:12
I too have used this method a couple of times. I have often thought someone with lathe experience could simply weld rod of the correct diamether to the new rod end and finish the threads all the way out the rod. Might not even be able to tell it was done. That is a thought from someone who has never used a lathe.
Rick H. Ga.
12-07-2002 17:36:03
Hi Roger,
I have the same kind of draglinks you have. A couple of years ago when I restored my 49 8N, the front draglink ball joints were fine but the rear’s were in rough shape. I didn’t want to spend $200 + on draglinks, so I cut the rear joints and bought two new short draglink ends, cut them to the right length and welded them onto the long draglink. I worked very well and was much cheaper than buying new draglinks. HTH. Rick H. Ga.
