Flooded? Stuck Float?
Phil
05-31-2000 06:39:07
I just had someone re-build the carburetor on my 8N. When I try to start the tractor now, gas starts coming out of the carburetor and it does not want to start. I'm not giving it any gas (or a very minimal amount) Is it flooded? Is the float stuck? Is there an adjustment I can make to correct the problem or am I doing something wrong?
Fred OH
05-31-2000 08:31:37
 Re: Flooded? Stuck Float? in reply to Phil, 05-31-2000 06:39:07
Hi Phil from Fred,
Usual reasons for your problem. Either the float is stuck, try taking a striking tool and tap the carb, sometimes that will work. Or the float has a hole in it filling it with fuel and changing it's setting or a piece of dirt has gotten into the needle and seat. To check this, shut off fuel to carb, disconnect lines and fittings to it and take it off. Now, a clean workspace (a towel on a bench not mom's table, it has gas in it). Take the screws out that hold the two halves together being careful to hold it upright when separating halves. Look in bowl for dirt before dumping. Usually a little pin holds the float in, remove it-lift out float and shake it. Should be empty if made out of metal. Needle valve usually attaches to float assy. and comes out with it. Lay aside and take bowl assy and blow out where gas comes in carb. Next check the float setting. If you don't know it, repost and someone will tell you how to set it. Reassemble just the opposite, hook up and test. If problem is solved, grin. If not, take it to the fellow that rebuilt it. L8R----Fred
