Before I take my 6 volt battery to town, to see about a load test, does this make sense: If I leave a charger on it, the battery seems to take a charge, but seems to be dead after turning the engine over 3 or 4 times. If after I charge the battery fully (so says the charger, and hook the negative clip directly to the starter, set the charger at 12 volts, and use the 125 amp charger boost, it still only turns over for maybe 4 seconds. Then the battery needs a charge again. Oil is 10-40 and air temp is in the 20s. I'd have thought it would wiz to a start that way. I've done it before with good results. Usually it starts just fine even in single digit temperatures, even without help from the booster/charger. 1. Is there a home method to load test a battery with a voltmeter? 2. How about if the battery is dead totally, and I try to measure resistance between the poles? Would it be different (higher I suppose) on a good battery than a bad one? 3. What else could be wrong which would explain this. I checked my points and plugs. The points are not welded together, and I don't see any indication of hydrostatic lock. I had not used my tractor for several months, but need it now for snow removal. If I have to buy a battery, I am open to brand recommendations. The one I now have is a New Holland, and it is 4 or 5 years old.
