Hi y'all. I "finished" the engine rebuild I started last March. I have good compression (90-100-100-100 dry). (Dang, whats up with #1? Good enuff, I guess.) New copper core industrial grade spark plug wires give a nice blue spark. The tractor was 12-volt when I got it so I kept it that way, but I did replace the wiring following a wiring diagram found in the archives.I have hooked up a temporary gas tank - a clear vinyl tube about 1 ft long and 5/8 inch ID, so I can troubleshoot problems without the hood and gas tank in the way. Naturally, the tractor won't start. The muffler is not connected to the manifold yet. When I turn the key and press the starter button on the dash, the engine turns and the cylinders fire (I think). Bluish grey smoke (mostly blue) comes out of the manifold (would go out the tailpipe if the muffler was connected) and I hear the popping of the cylinders. It sounds pretty good, really. But when I release the starter button, she just won't run on her own. Usually she stops popping right away. At best the engine turns on its own for a few pops. I don't think I can get her to pop all four cylinders more than twice without the starter button pushed. I have seen the spark. I have measured the compression. I can see and hear evidence of combustion in the cylinders (blue smoke and popping). I can even see that fuel is being consumed (thanks to my see-thru gas tank - no leaks, by the way). The thing oughtta run! The archives point me in the direction of two possibilities. Could I have screwed up the wiring such that the ignition circuit is only connected when the starter button is pushed? I have compared my wiring to the diagram several times, but... The other possibility is the carb. I did not rebuild it, or for that matter, even touch it. Even though my cylinders are firing (I think), could the air/fuel mixture be wrong and causing this thing to not run on its own? I was VERY careful to make sure my timing marks were lined up when I re-installed the crankshaft and camshaft. But... could this be the problem? The camshaft gear is new. What if it is marked wrong? (nah, that couldn't happen, could it?) By the way, I have not yet checked the voltage at the coil. Need I do this with nice blue spark? As always, any and all comments and suggestions are appreciated. If I've left out something important just mention it and I will fill in the blanks. Thanks, Ron
