Order Ford 8N Parts Online
How much can a 8N push? (pic)
Philip
12-10-2002 04:01:14
third party image
This is a picture of my 1950 8N (3300 pounds with rear tire ballast and back blade on) pushing my non-running 1961 6000 diesel (7000 pounds and no brakes!) into the pole barn. The pole barn is slightly up hill. It took 4 tries, but finally got the 6000 in. Had the front wheels up in the air on the 8N every time. If I have to do it again, I will probably hook up to the rear utility bar to keep from popping wheelies, or just use my truck. Time to start working on the 6000. Philip.
JDinSC
12-10-2002 08:59:59
 Re: How much can a 8N push? (pic) in reply to Philip, 12-10-2002 04:01:14
I didn't know the bumper was that strong! I've avoided a lot of work not trusting it. I guess it'll do more than I realized.
JD
DON TX
12-10-2002 08:16:18
I think I would have pushed from the rear of the 8N. Would have been more stable. Hooked to the rear bottom clevis hitch would have given good control. The leverage from the drawbar might work against you. HTH
DON TX
Dave 2N
12-10-2002 13:35:34
 Re: Re: How much can a 8N push? (pic) in reply to DON TX, 12-10-2002 08:16:18
Wouldn't have had enough traction to pudh it in reverse.
ah yes . . . Dell (WA)
12-10-2002 08:41:13
Backing a double linked wheeled object uphill with foward traction bar ag tires, makes perfect sense..... .NOT!..... ....respectfully, Dell who thinks Philip did it right
PROBABLY RIGHT---DON TX
12-10-2002 18:03:39
 Re: Re: Re: How much can a 8N push? (pic) in reply to ah yes . . . Dell (WA), 12-10-2002 08:41:13
Thats why I put doors on both ends of my shop.
DON TX
Steve W
12-10-2002 07:59:02
Ron's right....probably not the smartest thing you ever did. If the front came off the ground, it means the hitch point on the big tractor was too low. You want the front to be pushed sideways or down. But I bet when that front end came off the ground you had good traction....lol.
Be careful
Take Care
Steve
Ron
12-10-2002 05:35:16
I guess you have never had to pull someone out from under an upside-down tractor.... I have.....it AINT PRETTY... That damned thing could have flipped in a nano-second... PLEASE be MORE careful..... !!!!
uh . . . Dell (WA)
12-10-2002 07:58:01
 Re: Re: How much can a 8N push? (pic) in reply to Ron, 12-10-2002 05:35:16
Ron..... ....Philip said he had his rear blade on the 3-point hitch which extends behind the tractor and would prevent a rear axle tractor rotation roll-over. 2nd, the picture clearly shows the 2 tractors are mechanically linked by a long pushbar (pipe?) and for the pusher to lift its frontend high enough for a roll-over, it would also have to lift the 7000# pushee. Not going to happen.
Your point is well taken about tractor roll-overs, but in this case I think Philip did it right..... ..... ..respectfully, Dell
kevin
12-10-2002 14:15:42
 Re: Re: Re: How much can a 8N push? (pic) in reply to uh . . . Dell (WA), 12-10-2002 07:58:01
You guys reminded me of something I was going to do ages ago. I am going to put a recever in the garage floor so when something craps out, I can drop my "winchonapost" into the floor and haul the turd in. I also stand by previous comments I have made that a Four wheel drive pickup will outpull/push and OUT SAFETY any small tractor I ever saw.
Willy-N
12-10-2002 21:45:45
 Re: Re: Re: Re: How much can a 8N push? (pic) in reply to kevin, 12-10-2002 14:15:42
I drilled a 1/2 inch hole in my concrete floor for a harden 1/2 inch bolt to go in. Then I have a bracket to hook my cable com-a-long to pull them in the shop if needed. That is after I use my tractor to get them most of the way in. Mark H.
