Removing stuck pin
PickeringRick
12-13-2002 18:22:53
I'm trying to get the pin out of the yoke on my right lift arm, and it's stuck good. I've tried heating and cooling, and then hammering, but she just don't want to move (do I need to use more than just a propane torch?). I thought I read some posts about a month ago about the same subject, but can't find them in the archives. If I'm not mistaken, WillyN had a method. Any sugestions would be greatly appreciated.
hobo, NC
12-14-2002 06:24:56
 Re: Removing stuck pin in reply to PickeringRick, 12-13-2002 18:22:53
Pins are stuck in the knuckle. If you can not get them out with heat hears another way. Saw them out with a hacksaw then have them pressed out of the knuckle. Atleast this way you will not break anything.
Les, TN
12-14-2002 02:44:59
Ditto . . . re: peening it into a mushroom. It'll never come out.
Heat? Probably can't get enough on there with a regular propane torch. MAPP gas? maybe? Acetylene, absolutely! I had some king pins in a '69 Dodge PU that would not budge. Since I had it, tried the propane -- no go. Had someone bring in a real heat machine (acetylene) and they slipped right out. You'll need a big enough jet ta make some serious fire out there. Little ole welding tip won't do it. Need that cutting torch head (without the extra oxygen—you'll cut yur parts in pieces — OOOOoooo:( ) and a flame about 8" long.
Jay 2NSC
12-13-2002 22:13:41
Sound's like the end has flared.I took a file to mine and tapered the end of the pin.Soaked it in WD40,took a peice of 2x4 and a 2lb. hammer and coaxed it right out.HTH,:^) Jay 2NSC
kevin
12-13-2002 21:09:56
Pickering, Ontario?
PickeringRick
12-13-2002 22:44:57
 Re: Re: Removing stuck pin in reply to kevin, 12-13-2002 21:09:56
None other
Tim 2N-NY
12-13-2002 18:41:47
I kept spraying mine with PB Blaster, heating it with a propane torch, and finally pounded it out. You wanna be careful not to mushroom the head on it. I, of course, removed it from the tractor so I could wack it with a 3 lb sledge. Just took time, good luck. Tim
Willy-N
12-13-2002 18:31:31
Some times you need grind down the pin flush soak it good that way you are not pounding the mushroomed part into the yoke. Mark H.
