Order Ford 8N Parts Online
8n 1952 engine rebuilt, replaced crank, up running, steering problem
9n141
12-14-2002 18:53:13
1952 8n posted with bad engine-- update. Replaced crank & had it turned 20thou., with bearings to match. New oil pump ( we think this caused all the trouble). Put in Sherman o/u, runs good now. There was some play in the steering made adjustments, now steers hard. Did we tighten it too much?? Thanks to all who offered help. BURT.
Willy-N
12-14-2002 19:14:11
 Re: 8n 1952 engine rebuilt, replaced crank, up running, steering problem in reply to 9n141, 12-14-2002 18:53:13
Watch when you adjust the steering box. If you make it to tight you can wear the gears fast again. Problem is they wear in the middle more then on the ends (sector gears) so if you take all the play out in the neutral posision it will get tight when you make a sharp turn. Mark H.
