Order Ford 9N Parts Online
9n Ford Steering Sectors
Rick
06-02-2000 05:28:13
I'm in the process of renewing a 1941 9N. The question is, 'are the steering sectors oiled by fluid splashing up from the transmission'? It looks like there is an open area at the back of the sector box into the transmission case.
George
06-05-2000 13:47:48
 Re: 9n Ford Steering Sectors in reply to Rick, 06-02-2000 05:28:13
Supposed to be splash-lubricated, but I can attest from the condition of my 44's gears, that that doesn't happen. If you know where to get reasonably priced gears, let me know!
JerryU
06-02-2000 07:19:01
third party image
You have correctly assumed.
However, at least one tractor has improved on that. Mr. Tyler Neff's 9N which has been beautifully restored had a device installed by his Grandfather, I believe (I'm sure Mr. Neff will correct me if I am wrong) that routed lubrication off the hydraulic line through a valve which could be used to lubricate the sectors.
