Drain oil to pull off lift cover?
pbody
12-19-2002 13:25:20
I need to replace the draft control spring plunger. Do I need to drain the tranny oil before I start this. I was hoping to just remove lift cover and re-attach the plunger to the yoke.
Jim Spencer S.E. Michigan
12-19-2002 14:55:06
 Re: drain oil to pull off lift cover? in reply to pbody, 12-19-2002 13:25:20
If the draft control spring plunger is what I am thinking of, then there is no need to drain the oil. You may want to drain the oil and strain all the crud out of it though and then reuse it if you want.
Jim
Brian-2N
12-19-2002 14:04:48
Physically, yes it can be done. Practically, forget about it. The work you are trying to accomplish will be in the hydraulic fluid and you won't see what you are doing. Unless you have a helper and a real good "feel", drain the fluid.
