"Irrelevant" was a poor choice of words on my part. But this issue is so central to how a ballast resistor works, and its function in an ignition system, that I have to try one more time to explain. A ballast resistor is simply a coil of wire wound upon a ceramic form. It is not a semiconductor capable of exhibiting a variable resistance at the low test currents typical of (any) multimeter. What is the mechanism, in such a simple device, that makes the resistance variable? The answer is that the wire material is deliberately chosen to have a large positive temperature coefficient. As the wire gets hot, its resistance rises. The physical size of the resistor is designed such that it does get (very) hot in normal service. (Such design is not typical of most discrete resistors, because this temperature variability of resistance would be undesireable in most electronic applications.) The I/V curve in your photo is for steady-state conditions with a true voltage source applied to the resistor. The resistor is allowed to reach steady-state temperature. The current is measured, and the resistance calculated as R = V/I. This behavior provides multiple functions in an ignition system: 1) On an initial cold start, the resistor assembly has enough thermal inertia that it does not follow the I/V curve that you show. In fact, it allows considerably more current to flow, and thereby provides a "hotter spark" for starting. Once current has been flowing for a while, (and the tractor presumably started) the resistor warms up, the resistance rises, and the coil current is cut down. This helps to preserve the service life of the points, as well as reducing the thermal load on the coil. 2) Should the engine stall, you forget to turn the key off, and the points happen to be closed, the ballast resistor conducts current continuously, rather than at a 50% duty cycle, gets much hotter than with the engine running, its resistance rises, and the coil gets protected from thermal damage (the resistor gets hot, the coil doesn't). You can try this with your own tractor. 3) The slope of the I/V curve is such that the ignition primary circuit behaves as more of a current source than as a constant resistor. This compensates, to some degree, for undervoltage and overvoltage situations in the tractor electrical system. 4) The ballast is sensitive to ambient temperature, and will tend to increase primary current, and thus spark energy, at cold temperatures, when fuel volatility is reduced and "more spark" might be helpful. 5) The inductive properties of the resistor interact with the R/L/C circuit formed by the ignition coil and the condenser. This is what fried my multimeter, but it may have useful properties for spark energy and/or duration. Finally, a multimeter is not capable of supplying enough test current, to such a big lump of material, to warm it up at all. Without a temperature rise, the resistance of the simple coil of wire is not variable. Any (reasonable) multimeter applied to a (typical automotive/tractor) ballast resistor will read the same resistance value, regardless of the open circuit test voltage used within the multimeter.
