2nd gear use, brush hogging
Photofarmer
06-02-2000 08:22:06
If the second gear is the weak gear what gear should I brushhog or mow with? My brushhogging is really just mowing fescue on mostly flat clear ground.
ZANE
06-02-2000 17:34:28
 Re: 2nd gear use, brush hogging in reply to Photofarmer, 06-02-2000 08:22:06
If you are just buch hogging grass with no obsticles in the way then 2nd is OK. But if you happen to hit something really solid with it in second gear you are likely to destroy the second gear. I have repaired about 50 four speed Ford tractor transmissions over the years and 99% were second gear from bush hogging. For real!
Ed Gooding (VA)
06-02-2000 10:47:19
If you are mowing fescue on flat, clear ground, I don't see why you can't use 2nd. It's hitting something like a stump, muffler, or hat with a head still in it while in 2nd that will break the gear. If you don't have those hazards to deal with, then go for it!
Hope this helps..... ..... .....Ed
'52 8N475798
Tyler(MD)
06-04-2000 10:46:29
 Re: Re: 2nd gear use, brush hogging in reply to Ed Gooding (VA), 06-02-2000 10:47:19
Watch out for frying pans too!!! :-)
Ed Gooding (VA)
06-04-2000 13:37:43
 Re: Re: Re: 2nd gear use, brush hogging in reply to Tyler(MD), 06-04-2000 10:46:29
Hi Slim!
And BIG heads of cabbage!
LOL..... ..... Ed
From what I've read and what I've been told...
06-04-2000 14:29:22
 Re: Re: Re: Re: 2nd gear use, brush hogging in reply to Ed Gooding (VA), 06-04-2000 13:37:43
...you are absolutely correct. Better yet, watch out for a dog who has accidently eaten a box of exlax. :-)
third party image
Later,
Me
