Front Rim.
R.M. In AL.
12-20-2002 16:50:20
I know some of you fellows have run into this.I have my 8n front lugnuts off but cant get the rim to separate from the hub in order to take the rim off.What is the least destructive way to get it to separate.I have pried but I hate to beat it up tring to get it off.Its soaking in PB Blaster but I was hoping for a trick from you fellas..Thanks in advance...R.M. In AL.
duey in MN
12-21-2002 12:50:34
 Re: Front Rim. in reply to R.M. In AL., 12-20-2002 16:50:20
Got an air compressor? Buy or a borrow an air hammer (muffler gun) and use a flat set (not a chisel). With the axle supported, hammer around the inside next to the hub. Spray penetrant around the parting surfaces. The vibration is hard for the rust to resist, it should give up & come off. Good Luck.
OH Boy
12-21-2002 05:56:45
I had this problem with a rear wheel, put a hydraulic jack on it and snugged it up with some pressure (not enought to bend anything). Gave a couple of good hits with a 3# hammer and it popped right off.
Drmeatman
12-20-2002 17:24:36
R.M.inAL, I'm no "pro" but seems I've read here that one way is to loosen the lugs "slightly" ,maybe one and a half turns and then do a sharp turn with the N and that should do it.Sounds reasonable to me ! Your call tho !
RWK in WI
12-20-2002 18:15:39
 Re: Re: Front Rim. in reply to Drmeatman, 12-20-2002 17:24:36
I got a front wheel loose from my 3000 this way but it took about 10 minutes of doing figure 8's in the driveway. Be careful the loose lug nuts don't drop off. They can be hard to find in the gravel.
