Black Oil
Alan
06-05-2000 11:36:36
I have completely rebuilt the engine on my 8n , while I had it apart I also had the block tanked by a reputable machine shop . It came back looking clean and spotless . Since then I have run it qiute a bit and everything works fine , no complaints . I have changed the oil several times since the rebuild and have noticed that the oil is black . I thought it might be that way for the first couple of oil changes but it has been this way now for about 5 oil changes or about 100 hours of operation . Not sure if this is the way it should look or if this is an indication of something else . Any help greatly appreciated...Thanks Alan
Alan-could it be from a rich mixture ???
06-06-2000 12:32:15
 Re: Black Oil in reply to Alan, 06-05-2000 11:36:36
I do notice when I hit the throttle hard I will get a puff of black smoke ..Is it possible this is what is getting into the oil ???? Thanks..Alan
Jay Andrews(TX)
06-05-2000 20:43:38
Alan, are you by any chance using synthetic oil, if you are the rings probably have not seated. Just a thought..... ...Jay
Dave Todd
06-05-2000 17:39:12
I agree with both Clause and Michael, but I don't see where a fresh engine should have black oil. Maybe a little darker than fresh oil, but I tend to go along with Clause. Something ain't right somewhere if the oil is black so soon. If the rings are not seated, you would get some blow-by, and I can see this as ok for a while, but it still should not be black. Just my opinion. Good luck!!
Dave
Michael Az.
06-05-2000 15:41:36
When its time to change oil, if it isn't dirty, somethings wrong. Good oil is formulated to suspend dirt and contaminates so it goes out with your oil change. If the oil is clean, the dirty stuff is still in the engine.----- Michael Az
Claus
06-05-2000 14:06:35
Take a compression test. This is indicative of excessive blow-by. Happy Motoring
Claus
