Order Ford 9N Parts Online
Angle of valve seat on 9N
Russ
06-08-2000 07:24:46
I need to grind the valve seat on a 9N and am not sure on the angle to grind the valve seats. Are both the intake and exhause the same angle?
TimK
06-08-2000 08:38:14
 Re: angle of valve seat on 9N in reply to Russ, 06-08-2000 07:24:46
"Grind the seat to a 45 deg. angle using a seating stone or cutter. If a seat cutter is used each valve should be lapped in its seat. Seat width should not exceeed .125". If the seat requires narrowing, use a 30 deg. stone for the top of the seat and a 60 deg. stone for the bootom. " Intakes and exhausts are all the same angle. Keep the valves in the same order as they were removed.
