Order Ford 9N Parts Online
Tired 9n
rick
06-09-2000 18:36:02
i recently was running my tractor and left it to idle when i noticed the rpm dropping it stalled before i got to it it wouldn't restart so i thought i'd dropthe oil pan and have a look around i found that the plastic gear on the oil pump had only half the teeth it needed and the bearings on the cranks shaft 3of 4 have a bit of slop to them (conrod bearings)how much sop is allowed if any and what is the best fix for this ? Is there anything else i should look for while i'm in there. ie. piston tolerance
ps this is a 1941 version based on serial #
it also has one of those tricky front end loaders on it (it works well)lol
thank you rick
Andy (OH)
06-09-2000 18:53:17
 Re: tired 9n in reply to rick , 06-09-2000 18:36:02
I rebuilt my '41 9N in the spring and found the archives to have everything I needed to know. Everyone is also willing to to help in a pinch. Hard part was getting out the old sleeves but it's
possable to rebuild it yourself with a little work. Good luck and you've come to the right place.
ZANE
06-10-2000 06:21:24
 Re: Re: tired 9n in reply to Andy (OH), 06-09-2000 18:53:17
Getting out the old sleeves. EASY!
Their is a tool that you can use to drive the sleeves out of the bore with.It is best to have the crankshaft removed to insure that you don't damage the journals by striking them.you could have a maching shop fabricate one by turning a piece of round stock just a little larger than the bore of the cylinders.Firts turn a piece of stock of about 3/4" to about .020" smaller than the bore, then turn half of the blank to about .020" smaller than the bore of the sleeves.Cut about 3/4" from each side of the turned driver so that it will go into the bottom of the sleeve and with a 10 or 12 lb hammer and a large drift against the tool drive them out the top of the cylinder.
If you are a pretty good welder their is an easier way to get the old sleeves out. Lay the block on it's side and with a 6011 1/8" rod run a cold bead from the bottom of each sleeve to the top.Do this about 3 times in each sleeve and allow them to cool to the touch.You can then either pull them out with your hand or catch the bottom edge with a large screwdriver and tap them out. Be carefull not to weld through the old sleeve. After you get the old sleeves out lightly hone or sand the bore where the heat from the welding may have cooked the carbon to the bore slightly.Don't hone much. The new sleeves must have a .005 interference fit.
Don't try to drive the new sleeves in with the tool that you fabricated to pull them out with as that tool will split the sleeves when you try to drive them back in.
You can take a piece of flat plate of at least 1/2" thick and that will completely cover the top of the new sleeve plus about 1" or so and drive the new sleeves down till they are even with the deck of the block.Some of these N guys will tell you to freeze the sleeves etc but it is not necessary.I have done literaly hundreds and I quit that freezing bit years ago. Can't tell the difference.
dale b
06-11-2000 07:26:41
 Re: Re: Re: tired 9n in reply to ZANE, 06-10-2000 06:21:24
you are amazing zane. i am at this point and thought i would need a machine shop (big bucks) to do this for me. i think i will try your way. thanks for the tip.
dale b. ontario canada
