Order Ford 8N Parts Online
9n or 8n
Randy
06-19-2000 07:27:50
I'm just a novice, and would appreciate some advice on whether to buy a 9n or a 8n? Would like to use it to plow snow. Any advice would sure be appreciated! Thank-you
Jim.UT
06-19-2000 10:22:36
 Re: 9n or 8n in reply to Randy, 06-19-2000 07:27:50
tlak has sent you to a very good site for N tractors. If you think you might want to get a little newer, bigger, and dare I say better, you might want to check this site as well which also covers up through the Hundred series and early Thousand series.
tlak
06-19-2000 08:21:13
They are progressively better the newer they get. If you get a tractor for work get the newest, even on into the Jub,NAA,600s.Link bellow is a good site to read about the differance of 9-8s. The most notable improvements I would say was both brakes on the same side with the 8ns and live hyds with the JUB.
