Oil pump gear 9/16 3/4 ?
rich
06-19-2000 19:22:45
im sitting here looking at my oil pump and my gear is 1 inch od.where do i measure to get the right pump, im geusing there talking about the gears inside the pump, also clause and llamas you were right again pickup tube was loose where it was sweated on.also there was a washerin the back part of the oil pan ,its 2 in od 1 3/8 id it has a slot cut in od about 3/8, id is not round it has two flat places 180 degrees apartone flat place is 1/2 in, oposite side 7/8.the washer is splitat the cutout in od. also you can get pan off without splitting the thing appart.can anyone help?
Gary Tapp
06-20-2000 18:52:18
 Re: oil pump gear 9/16 3/4 ? in reply to rich, 06-19-2000 19:22:45
Rich, I believe you should be measuring the width of the gear from side to side....that measurement should get you either the 9/16" or 3/4". HTH
Gary
