Order Ford 9N Parts Online
9N Ford
April Hileman
06-19-2000 21:09:38
I have a 9N Ford that was running great til my husband took it out night before last . He says used it to pull someone out of a ditch then parked it in the drive.Now it won't start .It gets fire to the plugs . I did a complete tune up Pionts , Plugs , Plug Wires ,Roter , Condensor , Distributor Cap . Its getting fuel . I don't no what eles to look at . It has been converted to a 12 volt system . But the wiring loks ok . Any idea's or pointers would be appriciated
April Hileman
06-20-2000 22:40:45
 Re: 9N Ford in reply to April Hileman, 06-19-2000 21:09:38
Tried changing the coil this AM since computor was down had nothing better . also voltage regulator . Still no luck I'll try the switch next thanks for the input
homeboy
06-20-2000 18:25:42
April; You have gotten alot of good advice about your starting problem. I would like to add that the old 9N`s have a tricky ignition switch,(where you put the key)I would jump around that and see if that will help.If that is the problem just replace it. Not a big deal to a lady who can tune up a 9n. Good luck and be safe. homeboy
Glen
06-20-2000 08:24:54
If it is the coil they do make a 12 volt coil now for the 9n now.
Old Ag
06-20-2000 06:29:41
I tried everything you mentioned one time with no results. I broke down and replaced the coil. Then it fired right up good as new. 6V coils are about $40 at New Holland, $27 at TSC.
I burned up my coil by leaving the key in the ignition overnight, turned on. This keeps current flow through the coil (unless you're lucky enough to stop the tractor with the points open) and will run down the battery for sure.
Good luck.
Denny
06-19-2000 23:53:19
April , check to see it its getting fuel. Fuel in the tank? Remoce aircleaner pipe from carb choke it try starting and you should see fuel drip fron carb if its getting fuel.
Ken
06-19-2000 22:40:09
Hi April,
It sounds like you should have a runner. One question though. Did you replace all of the tune up parts before your hubby so kindly pulled someone out of a ditch, or after your tractor refused to start.
Ken
April Hileman
06-19-2000 22:46:16
 Re: Re: 9N Ford in reply to Ken, 06-19-2000 22:40:09
No, after he did that ,and ,after it wouldn't start
Ken
06-19-2000 23:20:46
 Re: Re: Re: 9N Ford in reply to April Hileman, 06-19-2000 22:46:16
That changes things a little. How was the coil voltage adressed in the change and can I assume you have a nice fat blue spark? This is my 2nd attempt to re-respond. If the first one appears out of thin air please don't think I'm schizoid.
Ken
