Order Ford 9N Parts Online
9n runs,no power
Randy
06-19-2000 23:11:27
help, No power but runs.Did a tune up,no change.Where else do I look?
Bob [ME]
06-21-2000 03:09:56
 Re: 9n runs,no power in reply to Randy, 06-19-2000 23:11:27
I've had this problem twice. First, I had the plug wires switched as described previously. Second, it was dirt in the carb. Hope the your solution is as easy.
norm-wy
06-20-2000 08:08:20
Randy
Don't know how this all started but make sure you don't have plug wires to cylinders 2&3 interchanged. Many of us have gotten bitten by that little bug. Firing order is 1-2-4-3 in a CCW direction. If you go CW it swaps 2 & 3. FWIW
Kim Hartshorn
06-20-2000 05:07:10
I blame the coil for everything...for one thing it is not real expensive and it is easy to replace...and probably needs replacing anyway :-)
good luck
Kim
actually I am fairly certain that more carbs have been misadjusted because of bad coils than anything else
Ken
06-19-2000 23:30:02
Hows the compression? is something that just happened? need more info.
