Order Ford 8N Parts Online
8N hole in block
Ron Burns
06-26-2000 14:51:37
I aquired an 8N with a hole in block just behind the oil dipstick--Got tractor for just hauling it away--I may be able to have it welded and rebuild engine, but would rather get good block--Any advice on where to find block? If I can't rebuild I guess I'll just salvage it. Any advice appreciated.
Ron
bg
06-26-2000 19:04:07
 Re: 8N hole in block in reply to Ron Burns, 06-26-2000 14:51:37
If the hole is not too large, the block can be repaired by a competent block repair shop. There is a 48 at our local NH dealer that had a softball-sized hole punched out by a thrown rod, and they fixed it. Cosmetically, the casting will probably be smooth where the weld is ground down, instead of having rough sand-texture. I wouldn't scrap it. There are plenty of blocks around, costing up to $1200. Lately, I've run across several scrap N's from $200-600 with good blocks. Look around.
Glen
06-27-2000 08:02:24
 Re: Re: 8N hole in block in reply to bg, 06-26-2000 19:04:07
If the tractor is in fair shape other than the block, and your going to do a compleat overhall. I would look into a rebuilt short block, C-T FARM
1-888-8CTFARN $1299.
