Leak of something from rear hub
photofarmer
06-28-2000 13:16:52
I have a substance that looks like oil or grease slowly seeping from a rear hub on the inside after some pretty good box blade work. Is this a seal gone bad? Where else could I be getting this from?
Rick
06-28-2000 13:39:26
 Re: leak of something from rear hub in reply to photofarmer, 06-28-2000 13:16:52
It sounds like a oil seal. How are your brakes when you step on the pedal of the side that is leaking? If it is slow to respond it is an oil seal. Although it may take awhile for it to soak up into your brake shoes.
