Loss of power and backfires
Phil
06-29-2000 14:54:38
I recently acquired a six foot bush hog for my 8N. After running it through a small field overgrown with thistle, I took a break to top off the tank. When I tried to finish up, the tractor seemed to be loosing power when engaging the PTO and or going up hill and backfiring a lot. Can anyone tell me whats wrong?
Thanks
bg
06-30-2000 14:44:11
 Re: Loss of power and backfires in reply to Phil , 06-29-2000 14:54:38
Losing power and backfiring can be symptomatic of a number of problems.
Fuel flow(carb adjustment, or fuel supply)
Valve adjustment
Condensor
Timing(centifugal advance not working, worn distributor shaft bushings, etc.)
Coil
Spark plugs or wires
Governor(adjustment or wear problems)
How to diagnose?
One thing at a time. I like to start with the cheaper, more obvious things like spark plugs and wires, tune up, etc. Eliminate them and work toward the larger tasks.
Snow Plow
06-29-2000 16:45:35
Sounds like a fuel flow problem. You may have stirred up some particles when you poured in the gas. Check all the inline screens (at carb, in sediment bowl, into tank.) Clean with carb cleaner. If the problem continues you may need to adjust the carb main to allow a more rich mixture. A 6ft hog is a lot to turn. My 4 footer bogs down in thick grass.
Good luck!
