Who made it???
Rick in La.
07-07-2000 12:37:58
Hi fellas!! Found an old well worn brush hog for the 9N that I have never seen before...Apparently it was originally yellow with two 14 or 15" tires on the back which adjusted with a threaded rod. pulled from the drawbar, and had a square cover over the PTO shaft with a handle to move the shaft back and forth. It is about a 5ft job and looks to be a heavy duty unit, although i don't know for sure. Any ideas who made it??? Can the 9N handle it?? Thanx for your time!!!
Rick
Old George
07-09-2000 05:58:49
 Re: Who made it??? in reply to Rick in La., 07-07-2000 12:37:58
Rick,
No idea on the one you describe but I have seen several homemade types fabricated out of steel, angle iron, and such. Would'nt dare use one 'cause they are too dangerous. I've got one rusting next to the barn right now that I don't know what to do with. Whatever you do with it, be careful!
Alan Esch
45 2N 183513
