Take a close look at the article. What is easy for one skilled guy with time and facilities to do is not so easy to make at a price that enough people would/could afford to pay. Because of the unusual design of the distributor, especially the points plate, there's not much in the way of space to put in an adequate magnetic rotor. As you will see, the distributor shaft assembly had to come apart and have the points cam lobes ground off, and the magnetic rotor modified, to make it all fit. Phasing the thing is obviously a difficulty, since the experimenter had to modify the points plate to allow for an error in phasing. And so on. I understand why vendors haven't offered this. Add the cost of a new distributor shaft assembly to the cost of, say, a present 8N conversion kit, and you're over $200. The static timing approach of the front-mount distributor adds another level of complexity, and more issues to confuse and frustrate the customer. That's not to say that some bright spark can't/won't come up with a drop-in solution, and if it would work with a 6-volt system and the current coil, I think it would be a winner. But I don't think it can be readily achieved with the current Pertronix parts at a price (in money and complexity) that would make it profitable. JMHO llater, llamas
