Dell
follow up questions
Al PA
07-09-2000 09:35:44
We're getting there. After charging the battery overnight, I was able to get the old girl started. I adjusted the carb and took her for a spin.
It has much more power than it did the past two days and it ran fine in 1st, 2nd, 3rd and reverse. As soon as I tried to start out in 4th or got to a small incline, she started to backfire and almost died altogether. Also, it is very difficult to start, but seem to run smoothly once it starts.
The one thing that is still off-spec is the timing. My measurement is closer to 1/2" than 1/4" - could this account for the problems I am experiencing?
Regarding your suggestion about the plug wires being switched, there are two wires held in clips on either side of the distributor (short wires in the top holes, longer wires in the bottom holes). I doubt that the mechanic bothered to swithch them around. There is not enough play for me to tug on a wire and trace it back to the plug without removing the tube in which they are housed. I doubt that they are reversed, but they are getting some age on them.
Dell (WA)
07-09-2000 10:38:29
 Re: Dell - follow up questions in reply to Al PA, 07-09-2000 09:35:44
Al..... ..Sometimes the 2 & 3 sparkplug wires are swapped at the sparkplug end especally if you don't have the tube anymore, not at the distributor end.
Yep, sounds like your ignition is incorrectly timed/gapped. Make certain you do it per the I&T FO-4 manual. The pictures explain so much better than words. Make certain your straight edge is on the "wide side" of the tanged shaft.
First, check your sparkplug wires and start and run your tractor. Then, consider your frontmound distributor timing.
Think of your daily driver car, ya' want advanced ignition when you're cruzin' for fuel economy but you need to retard the ignition some when under load like climbing a mountian. Remember some of those ol' Model T's, had 2 levers around the steering wheel, one was hand throttle and the other was spark retard for hand cranking? Sounds like your ignition is advanced which would make it hard to start and unable to go up an incline in 4th without poppin'.
Hope this helps, keep us updated, we care..... ..Dell
tlak
07-09-2000 14:35:40
 Re: Re: Dell - follow up questions in reply to Dell (WA), 07-09-2000 10:38:29
Nseries has what appears to be a pretty good step by step procedure for the front mount dist to include pictures. You experts on this can tell if a newbie should be able to follow this or if something should be added. The only thing I think they should have reworded was reading a multimeter. I think they should refer to a meter reading as having continuity and no meter reading as not. Somebody else posted a drawing of how to insulate the lead coming through the housing which is 5A in the Nseries pictures.
Al PA
07-09-2000 15:58:47
 Re: Re: Re: Dell - follow up questions in reply to tlak, 07-09-2000 14:35:40
A picture is worth a thousand words. I had the first two parts of the article from my manuals, but the "checking your work" section along with pictures 4 and 5 sure help to take out a lot of guessing. I'll print this out and insert it in my manual. Thanks to both you and Dell for your assistance.
