I don't have the original 6V...it is a converted 12V system. But I believe the coil is 6V (but a wild guess at that). I have a new 6v condensor. I didn't run the engine long at all. And my starting attempts were short (less than 15 second cranks on the starter). Could I have burned the points if I was pumping too much current into the distributor? Later this morning, I'll try to get a better meter reading and I suspect it's the wrong resistor, but what throws a loop in that logic is using the old resistor and I get the same results...???(worked fine before). But for now, I had to think through some of my steps and this is what I remember (my head is floating out there too...I ran my dog into the clinic last night and put her to sleep...too much pain for her...couldn't stand it any longer...sad :( At one point through this trial I set DC at 10. Got a 9 reading at top of resistor. Turned ignition on. Got a 3+ reading at top of coil and at other side of resistor. Wouldn't fire. Replaced the resistor (I got it from the guy at the Auto Electric store...who said that he has used these on another old tractor...and it is rated to drop V's to 4.2) with the NAPA ICR13 ceramic resistor (it's about 1.5 inches long two poles (one in, and one out). Same results...same reading. That's when I just connected the direct starter/ignition line to the lead of the coil. Turned ignition (holding these two wires together) fired up (I pumped my fist several times). Pulled wires apart, motor shutdown. Then I put the original round ceramic resistor into the circuit. Same results. I'll try to get a meter reading while it is cranking over...but hard to do...it's a long reach while holding the key open...but I can rig something up to hold one lead to ground and the other to the top of coil. I have the moring free before I go to work...will see what I can do. -9N'er
