Governor
Randy
07-11-2000 15:25:06
I am about to replace a governor on a 42 2N. This will make my 2nd one in about a month. The flyballs seem to be getting out of the holder somehow and it is completly destoring the governor, housing and all. I have used all the setting as instructed in the I&T manual but I have never had the governor to kick in. It seems to be "in" all the time even at idle when I move the throttle about 3 clicks, it wants to kick in and really revs up the motor. I will do all the adjustments on the new one before and after I install it but was wondering if anyone out there has seen this and might know of some causes of it and solutions.
ZANE
07-11-2000 17:50:40
 Re: governor in reply to Randy, 07-11-2000 15:25:06
If you have been installing new governors I see no reason for them to come apart like you are describing. There just aren't that many thing that you can do wrong installing an N governor.
Are the governors coming with the levers already installed and the spring? If so it seems like you may be getting inferior made parts.
Randy
07-11-2000 17:58:45
 Re: Re: governor in reply to ZANE, 07-11-2000 17:50:40
No, the first one was not new. The next one will not be new, but will have a 30 day warranty. The governors look in really good shape. I took them apart to look for slack and see if i needed to add a shim, but did need to. Under a load, it just does not kick in. I will double check all adjustments on this one. As I say, even with no load, the governor wants to kick in at about 3 clicks.
