Been thinking about this since I read it. Heres what I've come up with (my two cents): Standard POR 15 is not intended for gas tank restoration. The gas tank resotration system that the company sells is similar to Eastwood's products. It seems to do the job for gas tank issues. POR 15: I've had some minor problems with POR 15 flaking off. So, I'm careful where and how it is used. I use it now on interior surfaces (undernetath the steering column, behind the dash, underneath the transmission cover, inside the brake drum surfaces (except where brake shoes rub of course), underneath the chassis, inside the hood, inside the lower hood side pieces, interior of rims and hubs...everyplace that seems to collect water or places where water tends to run inside and sit etc. etc.). I never liked the claim of painting right over rust. Seems like it's a band-aid. So I sand- blasted and or grinded and sanded the rust, then used zinc phosphate to neutraliz and etch, then applied the POR 15. When I did that...it seemed to adhere pretty good...but in some places...it still seemed to flake off, and this is a concern. Other places, it was just like glue. I called the company and they highly recommended that the zinc phosphate be washed off before applying the POR 15(and in my case, I was not always that careful with that step...so I suspect that's where it flaked off...who knows). SO, with POR 15 there seems to be some element of "trickiness" to get it right and to adhere. The next thing...is to get paint to adhere to the POR 15. Applying their tie-coat primer when the POR 15 is curing but not all the way...but with a slight finger drag to it...seems to be the trick. When I let the POR 15 sit for a day or two...it was like a plastic/glossy/film...and it needed to be scuffed. So far...so good for me...but time will be the acid test for this. If Nolan and his experiences with POR 15 turn out to be true for me, I'll wish that I knew beforehand and knew about others' disatisfaction with the product. Live and learn is the old saying....but I am now watching it with a slight raised eyebrow...keeping my fingers crossed..hoping for the best. -9N'er
