*$# 3-point
Andy(WI)
07-16-2000 08:51:07
I have posted a couple of times about a problem I'm having with my 3-pt. not working. I removed the right side inspection cover and took a good look inside. Well, I'm no mechanic so I didn't really figure out what all the stuff in there was supposed to be doing. I'm going to get a manual and try again. In the meantime, as I have posted before the lift is in the up position and will not move. I have read so many posts about 3-pt dropping but none on 3-pt. stuck in the up position. I have attached about 400 lbs to the lift arms and it still won't drop! Yes, the PTO is engauged and movement of the lever does nothing.
Sorry for the long post, and thanks again for your past advice.
PS - I adjusted my steering box and she is steering like new.
