Alan, I just looked in my (original) 1946 parts book. YES, both main and rod bearing caps have castle nuts, AND there is a cotter pin called out for the rod bearing cap. Specifically, direct from the parts book; Part No. B-6348 NUT - spec. castle 1/2-20 - bearing cap studs Part No. 18-6212 NUT - connecting rod - special Part No. 352250-S PIN - cotter - special HOWEVER, My (original) 1956 Parts book shows that the main bearing studs have been replaced with bolts AND the rod bearing cap has two nuts, one locking the other. Again direct from the parts book - [added info by me]; Part No. 8N-6345-A Bolt-Crankshaft Main Bearing Cap [shorter for the plain caps] Part No. 8N-6346-A Bolt-Crankshaft Main Bearing Cap [for oil pump] Part No. 34809-S7 Washer 1/2" Lock [for above bolts] Part No. 354128-S Nut 3/8" - 24 (Connecting Rod) Part No. 45218-S Nut 3/8" - 24 (Connecting Rod Lock) The bolts are shown for the 9N,2N,8N only. The nuts are shown for 9N,2N,8N,NAA,600,700,800,900. Hope this information is helpful. Maybe Zane can add his years of expearence to this thread. Regards, Larry
