Order Ford 8N Parts Online
8N Steering Wobbling
Ross
07-20-2000 08:54:59
The front wheel on my 8N "wobbles" a lot during operation and it takes more effort to turn it to the right instead of the left. There is one bad ball joint up by the steering column, but this should not cause it to be this excessive. Any ideas?
Bill from MO
07-20-2000 12:02:07
 Re: 8N Steering Wobbling in reply to Ross, 07-20-2000 08:54:59
It sounds like the upper shaft bearing has got dry and has come apart. To check this, watch and see if the steering wheel goes up are down while turning. If so, the bearing is probabley bad and needs to be replaced. As for the wobble it can be adjusted if it isn't to badly worn. It sounds like you have the early type and they are bad about this.
