Hole in bottom of carb?
rob 8N KS
07-24-2000 07:22:12
I noticed today (when my 8N wouldn't start) that my carb has a hole in the bottom of it that is leaking fuel.
The I&T shop manual has describes this hole as an "air horn drain". The Ford service manual describes this as two parts: 9692 and 9694, plug and strainer respectively.
Right now, it just leaks fuel out of the hole. Did I lose a filter or something out of there? How do I fix this? I presume the carb bottom will have to come off.
Gerb
07-24-2000 19:14:54
 Re: hole in bottom of carb? in reply to rob 8N KS, 07-24-2000 07:22:12
The two holes are for a drain (small pipe plug) and a strainer. The strainer is brass, is flush with the bottom of the carb and I do not think it is intended to be removed regularly.
In your case the strainer may be missing.
Gerb
Tim Schaid
07-24-2000 11:53:53
The hole was designed to let water out of your carb if and when you ever get water in your fuel. I think your float is stuck. This would explain why it wouldn't start - it is probably flooded. Try rapping on the underside of the carb with a wrench to see if that will release the float, then drain the gas out of the carb by un-screwing the drain plub (1/8th inch pipe fitting) on the underside of the carb (be sure your gas is shut off at the sediment bowl). Re-plug, turn on the gas, and try again. You may need to drop the carb and check the float, needles, and seats.
rbell
07-24-2000 08:43:51
I would check the float, sounds like it or the needle valve/seat are not shutting off the flow and therefore gas is running out any hole it can find
