Glad you had so little carbon buildup in your engine. The type you describe sounds perfectly normal. So you won't be seeing the phenominal changes in engine personality that I did. That's actually good. One shouldn't let an engine get to the state mine was/is at. These engines are darn low compression, so it's possible for a bit of paint to hold the head down. Add to that a good head gasket with nice sticky stuff still left, and you could probably run some of these machines for six months without head bolts before the head would finally come off. What's the scoop on head gaskets? Well, I kinda like them and recommend them. Yea, I've run flat head engines before without them. You gain compression (theoretically at least), but you lose air flow into the cylinder, so you may have a net loss. Anyhow, that's probably not what you're asking about. Head gaskets these days tend to go on dry. There is just the right amount of sticky stuff on them from the manufacturer. Follow the head gasket makers instructions on using sealant or not. Truth be told, I don't know what New Holland says or what the new head gasket looks like. I took my old one, cleaned things up, smeared it thinly with my favorite ultra copper, and put it back on. I was kinda surprised to see how the various head bolts go down into the crankcase water jacket or oil area. That would promote leaks. I thought about applying a little bit of goo onto the threads of the bolts when I installed them to help seal them, but I didn't. Just lightly greased them instead. If I leak obnoxiously, I'll do that. T'wasn't me that gave prices or head skimming numbers. Don't know them, especially for these engines. Skim it if you want, but I don't see an inherent reason to do so. These aren't high compression racing engines, so I just don't really think there's going to be a need of it. Don't remember seeing it in the manual, but when you reinstall the head, follow the basic torquing path (around the head, starting in the center working out), but do so in incrimental steps. My own is to go first time around just seating the bolts. Second time around to around 10 ft lbs. Third time around to 25 ft lbs, fourth time around to 50, sixth time around to full torque. Wait a little while, recheck final torque values. Takes a little longer, but you tend to get a better result this way. Btw, Eastwood sells these nifty plastic socket inserts so you won't damage the finish on your nuts and bolts. :-)
