Order Ford 8N Parts Online
8N oil pump
Rick in Utah
07-26-2000 04:32:40
I have inquired and have seen all the information everyone has been putting up on the board about the oil pumps and priming them. I read that it is best to pack the pump gears with oil soluable grease. Is there a particular brand and if so is it at the local auto zone, checker? I also don't understand the "bushing" that has to be fit on the gears??? I called the local ford dealer and he sells the rebuild kit, but said nothing about the bushing that must be sized to the drive shaft.
tlak
07-26-2000 10:01:46
 Re: 8N oil pump in reply to Rick in Utah, 07-26-2000 04:32:40
Ive used vaseline with success. I use bearing lube on everything and vaseline in the oil pump.
Gaspump
07-26-2000 05:29:21
The bushing bearing must be line bored to size to properly fit the shaft to obtain sealing clearances. They will not fit on the shaft as they come out of the box. The assembly grease is available at most any auto parts store or machine shop.
