Order Ford 8N Parts Online
8N won't start
Roman
07-26-2000 20:25:16
Hey folks. First of all, thanks to all of you who took the time to help me with my problem. You have been most helpful.
Anyway, I ended up going through all of the wiring and tracing any bad connections. As it turned out, I was getting a current going into the coil, but no spark anywhere going to the plugs. I ended up removing the distributor and putting in new points, condensor, gasket. Put everything back together, and bingo, she started as soon as I hit the button. Looks like moisture did get into the distributor when I washed it down.
Thanks again for all of your help
Roman
