Loader cylinder leaks
8n64something
07-30-2000 16:11:28
the dump cylinder on my loader drips steady around the large packing (?) nut. The coffee can I hung under it catches everything, but I get to watching it swing around...couple of close calls there. Thought I might be able to just tighten the nut up, like a water valve, but couldn't budge it with a 4-foot bar. If I heat it to turn the nut, what are the odds of A) succeeding 2) making it worse C) toasting the cylinder. Any thoughts? Or is it a different type of seal?
(someone suggested soaking in beer a couple hours, it helped a lot but the nut still won't turn)
Mike OH
07-31-2000 06:56:43
 Re: loader cylinder leaks in reply to 8n64something, 07-30-2000 16:11:28
Sounds to me that you will need to replace the seal. I believe these seals are a packing material and with the nut being down tight, probably has compressed the material to its fullest. I don't think I would use any heat, as I think you have run out of thread adjustment and you might also start a fire. Be safe and not sorry. Good luck.
8n64something
07-31-2000 15:01:25
 Re: Re: loader cylinder leaks in reply to Mike OH, 07-31-2000 06:56:43
thanks mike, i'll stick to mechanical force...although i never hardly ever start fires with my torch
John in NH
07-31-2000 16:44:35
 Re: Re: Re: loader cylinder leaks in reply to 8n64something, 07-31-2000 15:01:25
If you can't turn the nut the packing is fully compressed. Remove the nut pull out the packing so they can be matched for size and amount,some large cylinders have 5 or 6 rings of packing. After you install the new packing tighten the nut until there is no leaks. Not to tight or the cylinder won't operate. Good luck. John
