Hydraulic control arm questions
Roger
08-01-2000 12:16:12
I have a 8n that I've removed the lift cover because of some cracks and a broken arm. I looked at the control arm that drives the intake/exhaust valves in the pump and it's got a big curve in it. The part # cast into the side of the arm says 8n524 in raised lettering (not stamped). My books show a good part as 8n504.
Is the 524 a curved version of the control arm? Is it supposed to be curved?
Does anyone know of a place where I could find out what a 8n524 should be? It does not show up in any of my parts manuals.
Thanks,
Roger.
ZANE
08-01-2000 19:16:24
 Re: hydraulic control arm questions in reply to Roger, 08-01-2000 12:16:12
The control arm is supposed to be straight. The control rod has probably been bent by someone taking a short cut to adjusting the lift. Sometimes it will work after a fashion and sometimes it just makes matters worse. The best thing to do is to straighten the control valve rod and then proceed with the proper repair and adjustment procedures.
I have a booklet and a jig that I have compiled and fabricated after the jig that was originally issued to all Ford tractor dealerships as a part of their required tools to hold a franchise.
If you want to know more about it just Email me at wzsherman@aol.com
Steve IA
08-01-2000 14:39:38
I just renewed my lift cylinder o rings and found my control arm bowed so much that I couldn't get proper adjustment. On advice from other board members that it should be straight, I straightened mine best I could and put it back. Works fine now. HTH.
Steve 8N 169302
