No power
Paul
08-06-2000 20:53:53
This is my first tractor so I am new to this. I usually deal with 50's and 60's fiberglass boats, but I love this 1943 9N. I traded for this and it ran until I got it home. Come to find out the breather had water in the oil and the carb had water in it at sometime. I rebuilt the carb and it runs good but doesn't seem like it has the power it should have. I can take off in 3rd gear and it just won't seem to pick its self up. There is a lack of power here. I am open to all suggestions on what I should look at next. How are you supposed to set the carb? It idles good and will run good at high rpms but under a load it doesn't seem to have any power. Thanks in advance.
Paul
roger
08-07-2000 16:42:15
 Re: No power in reply to Paul, 08-06-2000 20:53:53
I'm a rookie on this but FWIW,,,, I was just reading the carb section of my service manual. It talks about the situation you described word for word. If I remember correctly it indicates the power needle (wording?? I don't have the manual right here) should be opened up. I believe it's the larger of the two screws towards the front of the carb and I think it says to open it another 1/8 turn. I think it also talked about the governor being set correctly but I didn't read anything on that yet.
Have fun & good luck,
Roger.
Dell (WA)
08-06-2000 23:27:58
Paul..... .sounds like ya' ain't got the governor hooked up. Check the I&T FO-4 manual or brouse the "archives" at the top of the page..... Dell
